kennyd63's avatar
kennyd63
Flat tire!!
On my way back from New Orleans I had a flat tire on the T.T. I was not able to take the lugs off ,so I call for service. They sent someone, he took the flat tire off and replaced it with the spare. He used a battery drill with an 1/2 inch socket on it. Well we kept going back to Chicago when I arrived I decided to put the original tire back after fixing it of course. To my surprise the lug nuts where loose, here I was thinking that this drill torqued the lugs to specs and that everything was ok. This tire could of came off at any time. What kind of service people are this?:M
  • kennyd63 wrote:
    On my way back from New Orleans I had a flat tire on the T.T. I was not able to take the lugs off ,so I call for service. They sent someone, he took the flat tire off and replaced it with the spare. He used a battery drill with an 1/2 inch socket on it. ... To my surprise the lug nuts where loose, here I was thinking that this drill torqued the lugs to specs and that everything was ok. This tire could of came off at any time. What kind of service people are this?:M
    Who is this "they" who sent someone?
    A drill with a socket will troque the nut to some unknown torque which, in your case, was clearly insufficient. In other words this is a lesson learned - battery operated drill should not be used anywhere hnear a wheel. Even an electric drill. Maybe one of those compressed air drivers with torque sticks in a pinch, but I don't like them. I prefer a torque wrench or tighten by hand.
  • Usually supposed to re-torque after 50 miles on any wheel, RV or automotive.
  • The lug nuts need to be re-torqued after the wheel is changed out. I bet that there is a warning sticker somewhere around your wheel wells that tells you to retighten the lug nuts a couple of times.
    A good torque wrench is very important to make sure your lug nuts are properly installed.
