mangchibike
Jun 10, 2013Explorer
flat tire
i just picked up brand new tt (2014 outback 250RS) from a dealer and stopped my home then went to friend's house for storage (total 70 miles) and when i went back following week to try out camping, there is flat tire (no one notice cuz it was covered). So I tried to remove it using 7/8 deep socket (the manual says use 7/8 or 13/16) and i stripped a wheel lug nut so i stop and pump the air and went to local tire shop but it took them 4 hour to remove and fix flat... (well it was small parking lot, and i had to park side of the street and they had to bring all the tool and it was 95 degree day)
By doing this I had to buy all the tool from deep socket, torque wrench, air pump.. everything..
So i made a first trip and went back home check the tire pressure and it did loose more than half (62 to 30). I just could not believe.. so I tried to order new tire from a rv dealer and to get the same tire they don't even know how long it is going to take... (trailer king ST225/75R15 load range D I think they only deal with towmax tires)
So here is the questions
1. can I use different brand tires? I don't think it make a diffrence..
2. why is tt doesn't come with jack and wheel lug nut wrench like cars?
3. I tried to talk to dealer and keystone directly requesting new wheel lug nuts (6 of them) and denied, even though the manual say ues 7/8. The service dept. says use 13/16.
4. this kind siuation what would u recommends? fixing yourself or emergency road service by insurance co? (found out later i could)
5. Do you check tire wheel lug nuts torque pressure often? (manual says so,, but most cars we don't and i don't want to touch them again
I just want to get this over,, change new tire and wheel nuts..
Thank you in advance
