fpoole
Jan 27, 2017Explorer
Hmmm... not sure I completely understand it, but I load mine on the truck flat bed. A little tricky at first, I put markers on the sides and try to back into alignment, centered...
With the Tie downs, I have fast jacks, it's always off a little bit each time, but basically centered. I put tape down on the bed at all four corners in a "L" shape for the mat to center and then center the camper on it. Usually within a 1/4 inch or so.. and it stays put. Make sure you have the proper setting for the tie downs, not too loose, not too tight.
Hope that helps..
Hope that helps..
44,066 PostsLatest Activity: May 13, 2026
