bondebond
Apr 09, 2015Explorer
I can't give you the direct answer but a trip just about any store with an automotive section, electrical section or household hardware will give you the option to buy a multi-tester, usually $25 to $40 for digital. Doing anything electrical on the PUP will greatly benefit from the use of a multi-tester, aka multi-meter.
With that in your had, you will know which wire is which. And it is useful for troubleshooting numerous other electrical issues, especially problem with a ground wire shorting out which is all too common.
On the tester, red is positive, black is negative. If you get a negative value on the display, then you know that your red tester lead is connected to a negative wire and your black tester lead is connected to a positive wire.
I keep a Harbor Freight $8 special in the tool box inside the PUP. I've checked it against high end multi-testers and it is accurate enough for what I need on the PUP.
