ajriding
Dec 14, 2021Explorer II
MFL wrote:
Don...in the past I've used black abs cement to fix damaged sewer pipes. You need to clean pipe with abs cleaner first, then add a thin coat of ABS black cement. While still wet, add a proper sized piece of fiberglass screen (same as screen in RV door) into the wet cement. Let dry, then add another thin layer over the screen, let dry. Over night dry time may be needed for a large crack. Three thin coats, until you can no longer see any screen should do it. I've never had a failure, using this method.
Jerry
Yep, I was trying to remember what I used on a house. It was this. I slathered on a drain pipe in the basement and used some cotton. I just kept putting on layers until the leak stopped. 10 yrs later it is still good, but the house has not moved in those ten years also. This might be better than two-part epoxy/resin as it should remain more flexible.
