Leaf-Peeper
May 04, 2015Explorer
We installed the Allure snap lock style flooring a few years back. It absolutely needs to float and not be pinched anywhere ..., yes like underneath those table leg supports, also underneath the toilet, and underneath the entryway trim that you'll probably install. If not fully floating, the product will shrink and actually unsnap itself in select areas when the weather gets colder, leaving gaps between the planks. When the weather gets warmer, the gaps close-up, but not fully and it won't snap itself back together. This has been our experience with the product, yours may vary. The product wasn't designed to be installed in areas that see a wide temperature swing.
