Mastiff_mama's avatar
Mastiff_mama
Flooded trailer
My neighbour camper just got back from running some errands and found the water running inside her trailer. Water is everywhere !!! She has mopped it up but what else can we do to help out here? She is crying her eyes out. The trailer is a newer Kodiak
Thanks
  • get as much water out and up and turn the heat on and get it hot and fans will get it dried up
  • Rent a "steam cleaner" to suck water out of any carpet.
    Open all cabinets to dry out.
    Get/rent a couple of those high volume fans (they sit on the floor and blow air across the floor) to dry out everything.
    Place some tools like screw drivers under the carpet flap on the slides so air can get under there.
    Run a/c.
    Need to dry out the unit quickly.
    If outside storage is wet, get some fans from Walmart.
    That's what I would do.
    Pat
  • Open windows and get some fans in there to circulate the air. Open cupboards and let the air circulate in there too. Find the leak and fix it. If its under warranty inform the manufacturer or dealer.
