What would be the best way to tackle this floor rot? The last 6 inches of plywood is rotten on the back. Can I cut a new piece of marine grade plywood and slide it in to replace the rotten wood? I ...
Here is what I was dealing with. You can see in the pics that the framing becomes very apparent once you pull away the rot. Tying back into it is a breeze. Of course you may be trying to protect your existing flooring etc on the inside. If that is the case then trying the angle iron/epoxy makes great sense. If you are going to rebuild anyway then getting rid of the rot and starting fresh is a great way too! lol
