Absolut's avatar
Absolut
Floor Vents and duct work
Jayco 26 ft TT. found the duct work was rotted out. metal just deteriorates when touched. trying to decided how to cover the vents. or would redoing duct work be as hard as I am thinking?
  • westend wrote:
    Home Depot also sells some of the tin and registers, flexible duct, too.
    wish the forum had like button. HD be cheaper for sure.
  • Home Depot also sells some of the tin and registers, flexible duct, too.
  • I'd suggest you perform a pressurized leak test. Sealtech is one business that does these or it can be done DIY with a blower.
  • westend wrote:
    There shouldn't be any thing severely hard about restoring the duct work, especially only the vent cover and connecting tin. If the plastic or foil duct is still intact, it may be possible to fish it out towards opening.
    I will look at it closer next time out there, just scared what I might find, but it isn't a large enough space for a body.
  • well, the tin that is directly under the vent is paper thin and falling apart. I just bought this for dirt cheap as it is filthy. 1997 262 eagle. need to replace back bedroom floor and a wall in the bedroom. Husband looked at roof and thinks it is pretty good shape. Have been learning lots reading all the threads. Back to the duct work... I cleaned one out of all the dog hair and that's when I noticed the tin deteriorating in my hands. below it was the pink insulation. I didn't mess with it.
  • There shouldn't be any thing severely hard about restoring the duct work, especially only the vent cover and connecting tin. If the plastic or foil duct is still intact, it may be possible to fish it out towards opening.
  • I have never heard of duct work "deteriorating".
    How old is the Jayco? Is the duct work metal??
    Do you have any ideal what made it deteriorate?
    The vents can be covered with a vent cover material from Wal-Mart.
    To replace the duct work is doable. Would be a pretty good job. It would have to be replaced from underneath.
