jamnw's avatar
jamnw
Refrigerator vent duct fans
I just finished my refrigerator modification.
It took about 1 hour total to complete.
I can't get good pics of the fans themselves. They are mounted at the top of the access panel cutout.
I used two 12V computer fans and screwed them to the wood frame.
I wired them through a 110V wall switch I had lying around.
I drilled a hole through the switch handle, and put a stiff wire through it so it sticks out the access panel vent holes.
I use the wire to turn the fans on/off.
*I eventually plan to put a thermostat. Can someone point me in the direction of a thermostat to use?
I hesitate to say the whole mod cost me zero dollars, but the fans came from a co-workers retired PC, the wire was scrap, and the switch was from a remodel we did a few years ago.
Here is the switch. I may or may not clean it up! LOL
Here is the wire sticking out of the vent. Yes the camper needs cleaning!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
