a_flyfisher
Oct 26, 2016Explorer
Bob B wrote:
I used to have the horse mat under mine, but decided to remove it because of the amount of weight it added ..... That stuff is VERY heavy.
I installed this green foam which has the highest compression rating I could find without special order .... I've put quite a few miles on it with not problem so far .... If I do have problems around the edges, i will put some boards around the perimeter.
That is quite a nice looking setup you have there. I also like the idea of that piece of rubber mat - or what looks like a rubber mat - at the front end of your truck bed - to protect the front end of your camper.
Can any of those thicker, rigid rubber mats be cut with a circular or table saw?
44,068 PostsLatest Activity: Jun 21, 2026
