bigfootford
Nov 15, 2016Nomad III
TxGearhead wrote:
10-4 Thanks.
What seemed to be attacking pad?
The screws and just the bottom of the camper rim the supports the weight of the camper and the bottom rim around the front and passenger
Going around corners etc wii put forces of the weight into the sides or when putting the brakes on the weight of the camper will be trying to move forward and down in the front....
Like HMS said... STAMPING... If you need to raise the camper up do foam on the bottom then Plywood and then the top with rubber if you want...
Jim
44,068 PostsLatest Activity: Jun 21, 2026
