Golden_HVAC
Jun 13, 2014Explorer
Hi,
I had a 94 work truck that would ping when the A/C was on "Max AC" while going up a hill. This is because there was a vacuum leak in the outside air door.
You might try running normal A/C and then know that if you do decide to use Max AC while going up hills, you need to fix the vacuum leak in the door (about $200 - $400 in shop time) before the system will work right. However if it works on regular A/C under full throttle applications, then all will be well, even if not fixed.
You are still getting cool air, just it will be coming out the defroster vents. This indicates a vacuum leak someplace. Very easy to fix, once you know the location of the leak. It might take a hour or so of shop time (normally about $90+ per hour) to figure out the leak location.
There should be a check valve so that the system continues to get vacuum while at full throttle. It might be leaking, and installing a small vacuum reservoir would also help, it will look like a round ball or something the size of a coffee can with a vacuum port on it.
You can also just let off the throttle for a couple of seconds, get the vacuum level back up, dash vents will open again, and continue on your way up the hill.
Good Luck,
Fred.
Good Luck,
Fred.
