Hybridhunter
Aug 07, 2014Explorer
bobx2 wrote:06Fargo wrote:
This looks like a great engine at 325HP.
That is about the same power as my trusty 5.9 Cummins ISB.
On edit: If each engine is in a 1 ton chassis and matched to it's proper transmission and rear axle ratio -
Towing at 23,000lbs GCWR the 2.7 Ecoboost will run right beside me up the "Ike Guantlet" then, right?
:h
Not a chance in hell!
Do tell how you reached that conclusion. At WOT, if they both have 325 hp, and the Ford is able to tap that horsepower, it should be close. If either is caught in a situation where it doesn't have the " correct gear", the one with much greater torque, the cummins would prevail.
44,070 PostsLatest Activity: Aug 07, 2026
