noteven
Aug 08, 2014Explorer III
As fast as possible to the top of a short hill while caning the hapless pickup engine (cue rock geetars) is very low priority.
I was hoping for someone to show the math how a 375lbs-ft torque engine can pull a grade or buck a headwind at the same sustained speed with the same weight etc. as a 600lbs-ft torque engine, based on identical maximum 325hp numbers.
My experiences with heavy duty trucks is higher torque is generally "better" in most situations, but that is a much more standardized vehicle segment - engines are rated the same way by SAE etc. and vehicle size and weights on the road are often nearly identical... so which engine will pull better becomes clear quite easily. In the wind and on the uphill it is the higher torque engine. Accelerating as the road levels out or from a standing start it is the higher HP engine. Those engines do not have 4500 rpm operating ranges to post "big numbers" at rpms that aren't efficient. So the playing field is quite level.
The pickup truck world seems a little more touchy when you question power and performance claims. :)
Sorry if I offended anyone.
I propose a forum term called Towing. It's when someone tries to tow the discussion back on topic :) vs Trolling...
Here is some dyno test data for Ecoboost 3.5L and a V8 non Ecoboost gas...Clicky
Quite a complicated matter to get all the controls and settings to behave themselves and cough up the information :). But good information.
If "someone" were to take a smooth running V10 of say, 7L displacement, (or say 6.8?) and make it an "Ecoboost" and give it power characteristics of 2X the 3.5L, and move the peak torque down to Only 700lb-ft at 2000 rpm, and limit the rpm/peak HP to "only" 550HP or so, that would be a nice RV puller for heavy RV trailers...
and deliver nice mileage empty...
