chr_'s avatar
chr_
Ford 4.6 Triton
Anyone towing with a 4.6L Triton V8 in a Ford?
F150, Econoline, Explorer, etc?
I have one in my Sport Trac. Does great on the flats, not so bad on the hills. I can pull a 6% grade for several miles dropping only to 65MPH if I start it at 80MPH pulling my ~6000 # Loaded TT.
It's the 4,500+ RPM's to climb the hills that concern me. People tell me these motors are made to spin being Overhead Cam, just wondering if they can really handle it. A lot of Motorhomes have the V10's and they do the same RPM wise.
Considering a 3.0 Ecodiesel Ram 1500, or an older 6.0L Avalanche if this truck doesn't hold up, bit I really don't want a large truck. Not sure the Chevy 5.3 in a Colorado will do any better even though they are pushrod motors. Give me a Dakota with the 3.0 Ecodiesel, then maybe that is the ticket.
I really like this Sport Trac as a daily driver. I just don't want a 3/4 or 1 Ton truck as a daily driver, and I don't want a truck sitting around just to have to tow the trailer either.
  • I drive a 5.4 Ford and Id rather have a 3.0 diesel. Not sure about having a Dodge truck around it but the fuel savings when unloaded ought to be pretty good. I've met a few guys that towed the same trailer with both their 4.6 and the 5.4. The MPG was nearly the same and the 5.4 had a small edge in power.
    FWIW, I hate spinning out an engine above 3K, and I know it's just me. I'd like everything to cruise at 2K-2100.
  • Hi,
    The Sport Trac is probably the lightest vehicle that the 4.6L is in, so the Econoline or F-150 would have a heavier curb weight. So in addition to the weight of the trailer, you would have a 2,000 pound heavier van or truck going up the hill, so it might not perform quiet as well.
    Starting the hill at 80 MPH - that does not sound fuel efficient or very smart. I guess you never found out that ST tires are only rated at 75 MPH?
    So my question is also why try to go faster than 55 MPH while climbing the hills? You have plenty of time. Well your time might be short if you keep going 80 while towing though.
    Yes the 3.5L Ecoboost is designed for 11,000 pound trailers and can do the job if you get the right towing package and higher GVWR package. Personally I Would rather have a 5.4L in a F-150 and tow with that at a lower engine RPM.
    Yes the 4.6L is rated at 4,500 RPM's. So is the 5.4L and the V10 has the same pistons and stroke as the 5.4L with 2 extra cylinders.
    Fred.
  • If you need to go 65 mph up the 6% grades, it's got to come from something.. ;)
    I recall pulling around 3500 rpms going 55 mph up the grades with my 97 5.4 F150 in 2nd gear..
    I could have hauled it up to to 65 mph, but why?? Still got up the hill doing a decent pace and it was comfortable for me...
    Anyway, you want to go fast but pull lower rpms?? Get an Ecoboost.. :)
    I now go up the same grades, towing the same trailer with a 3.73 rear gear (The old F150 had 3.55's) and I'm going an easy 60 mph pulling 2700 rpms in 4th gear (6 speed trans)... :)
    I could go 70 + if I wanted, but again, why?
    Good luck!
    Mitch
