PastorCharlie wrote:
The V-10 with 3 valve and 5r110 trans is rated at 362 HP and 475 ft. lb.  torque.
The V-10 with the 6 speed trans was chipped down to 345 HP.
The 5 speed is the same trans as the 6 speed but the 5 only uses 5 speeds depending upon the ambient temperature.  It will shift 12346 or 12356.
The six speed transmission is not the same as the five speed; it is a different design with entirely different ratios.  The five speed was technically a six speed internally, but fourth and fifth differ by only about nine percent and so are not really treated as separate gears (as you mention).  Most of the time, except in quite cold conditions, the actual fourth gear is the one skipped.
It's worth noting that the horsepower (and torque) ratings are at different RPMs with the two different engine tunes; from all I've seen, subjectively the engine is not less powerful with the six speed transmission, and indeed the overall package is superior to drive.  Apparently it's mostly tuned for a broader torque curve/power band, at the expense of peak power at really high RPMs.  (I read a claim that it was mostly a paper change to what RPM the power was officially measured at, supposedly to meet some sort of emissions or noise regulation that was imposed with the engine operating at its rated power, and the actual tuning hadn't changed all that much.  That may well be just an urban legend.)
