danrclem
Jan 18, 2016Explorer
Ford 6.2 Opinions
I'm planning on getting another vehicle for towing in the near future. I'm seriously considering a used Ford 4X4, 6.2 gas engine F-250 or F-350 srw. I thought about a diesel but I've pretty much decided against it because of the upkeep expense and price. Except for a trip to Alaska I don't plan on putting a lot of miles on it so mpg isn't that big of a concern. I'm planning on getting a small 5th wheel and I may on occasion pull an aluminum Bass Tracker behind the fiver for no more than 160 miles one way. I don't expect the weight of both to be much over 8,000 lbs. (probably not even that much) loaded.
From what I've read the 6.2 has been a dependable engine since introduced in 2011. I can't find much info here on rv.net so I'm asking for your good and bad experiences with this engine. Has it been dependable for you? Does it pull good and with what axle ratio and how much weight do you pull? Even though mpg isn't my main concern, what is your mileage in different circumstances?
Any replies will be appreciated.
Thanks, Danny
Thanks, Danny
