4x4ord
Sep 29, 2019Explorer III
rjstractor wrote:ShinerBock wrote:
Yeah. If this is sustained power, then it should easily mop the floor with the other two.
Advertisement laws do not require a manufacturer to advertise sustained power numbers. All they have to so is reach a certain power level in a short burst in accordance to SAE procedures which is at low altitudes. Some manufacturers factor in sustained power, and some don't. I wish sustained power numbers was a requirement for the J2807 tow standard meaning you can only advertise the lowest power an engine makes performing the up hill test. I have a feeling that some of the power ratings would drop considerably if it were.
Agreed. I'm not exactly sure how commercial truck engines are rated, but I have a feeling that the early 2000s Freightliner I occasionally drive will put out its rated 515 hp for hours at a time. I'd love to run it up the Ike pulling 60K combined against the new Ford at 40K. I think I know which one would do better...
I think you're right that a 515 hp engine in a heavy duty truck can put out peak power all day long. These pick up truck engines may also be capable of running at peak power all day long. It is possible that the reason they don't make advertised hp on the Ike run is due to the extreme elevation. I wonder if the turbos on the pick up truck engines are capable of pumping enough air at 10,000 feet elevation to allow full fuel to be delivered? Maybe fuel is restricted under those conditions to prevent excessive exhaust gas temperatures?
