ShinerBock
Sep 18, 2018Explorer
Hannibal wrote:ShinerBock wrote:Hannibal wrote:ShinerBock wrote:
Yeah, I would have to raise the BS flag on that too. I drove plenty of 5.4L SD's in the past as well and all of them would down shift to 2nd or 3rd at the sight of a hill when towing. They would get the load up the small hills, but it would be screamin' at 5,000 rpm doing 45 mph to get it there. I could just hum along at 1,700 rpm in 6th in my 6.7L CTD pulling the same weight up the same hill.
You're calling me a liar. I'm convinced you're a liar. I guess we'll just have to leave it at that.
Yes, I am calling you out for saying that your 5.4L only revs 30% more than my diesel pulling the same load BS. I have experience towing with 5.4L SD's and there is no way it will tow a 10k trailer up a hill at just 2,340 rpm which is 30% more than the 1,800 rpm my truck would do going 65 mph in 5th. Every 5.4L that I have driven would be screaming much higher than that at even the slightest of hill, and it you would consider yourself lucky if you were able to do the speed limit.
No way your truck will tow 10k lbs up a 6% grade 70mph at 1800rpm. You're still lying. Lol!
Yes, it will and has. Although I said 65 mph at 1,800 rpm, at 70 mph my rpm is closer to 1,950 rpm in 5th. You can YouTube it if you don't believe me. There are plenty of videos there. There is even a video of one towing 13,000 lbs up the Ike at over 9,000 ft above elevation in 4th gear at 2,350 rpm at 65 mph. I don't need that many revs for south Texas altitudes.
