MackinawMan wrote:
nevadanick wrote:
My experience with 7.3's is if it actually dies its the cam sensor. If it just goes to idle and doent die its the accelerator pedal.
Thanks Nick, it does stall completely....
With all the suggestions here I'm going to go with the cam sensor. I just priced one at $25 from Autozone.
Thanks again to all and I'll update you.
MackinawMan, in all fairness it could be several things including a few that has not been mentioned in this thread.
I recommend a CPS because of a few things. One is, it's cheap and a 5 minute job to replace. If I'm wrong, your out less than $50 and about 5 minutes of your time. If you don't have one you should put the spare in the glove box just in case.
