MackinawMan wrote:
nevadanick wrote:
My experience with 7.3's is if it actually dies its the cam sensor. If it just goes to idle and doent die its the accelerator pedal.
Thanks Nick, it does stall completely....
With all the suggestions here I'm going to go with the cam sensor. I just priced one at $25 from Autozone.
Thanks again to all and I'll update you.
Be careful with the after market CPS. I replaced mine with one from O'Reillys this summer. Started doing the same thing as yours but only when it was raining? Anyway after researching found after market CPS didn't have a very good reputation. Changed out to a factory Motorcraft CPS and no problems since. Good luck, John
P.S. Good advise to put an extra in the glove box.
