silversand
Dec 30, 2014Explorer
I like our open "C" channel ladder frame, with boxed frame under the entire engine area. The open C is extremely good a vertical load handling/stability (look at tractors pulling trailers), and is less rigid in torsional dimension (bringing loads over hilly terrain, the C channel torsional flexibility is needed to keep all 4 wheels on the ground, all the while providing exceptional vertical load stability with the C). Open C under the load bed area needs a different leaf spring rate design (just as rear boxed needs a different leaf spring design when compared to open C springing).
...if we ever had to go with a newer truck (God forbid), I would do everything in my power to source a truck/frame with open "C" channel, with ladders under the load-bearing part and engine/tranny of the new truck (I hope this would not have to be an MDt or Class 8 !)...
44,029 PostsLatest Activity: Jan 28, 2025
