Tystevens wrote:
ksss wrote:
Bluhorn wrote:
I know I will get beat up but I am not a Ford basher. But common sense should prevail. Of course there are some folks who may not have had a problem with this motor but overall the reputation of this motor is trash. Of course you could "bulletproof" one but why would you??? Why try too fix MAJOR issues and spend 5 to 7 THOUSAND dollars with no guarantee? The Ford 6.0 and to a lesser extent the 6.4 Diesels were litigated out of production! You could get a Ford V10 and get a great motor. Buy a used Dodge or GM Diesel and get something that has a WAY BETTER REPUTATION. ITS YOUR MONEY! I certainly wish you the best on your decision.
I don't understand it either. Why torture yourself with this decision. Its a gamble that will never pay off. They have no value, running or not running. Dumping more money into these POS's just puts you further in the hole (bulletproofing). Buy anything else except a 6.4 and your chances of TV happiness increase tenfold.
I'm another one who doesn't get it. I mean, it isn't like there is something really killer about the truck if it is working right. Ok, the crew cab is nice and big, I'll give you that. But you can dump a lot of $$ into it and hopefully have a truck that is as reliable and has almost as much power as the Duramax and Cummins from the same vintage!
If I had unknowingly bought a 6.0, I would totally understand putting some $$ into it to prevent against the known problems -- you would probably be money ahead over dumping the truck. But there is no way I'd walk into owning one at this point.
I'm not a Ford hater in any respect -- check out the vehicles in my signature. But hearing of the list of things you'd need to do to one of these trucks after you bought one always reminds me of the scene in Ghostbusters when Ray (Dan Ackroyd) is listing off all of the repairs that need to be done to their 'new' ghostmobile!
x 3...and I owned a 6.0 Ford...even after "bulletproofing(BTDT) there are too many components that still cause vacation ending disasters...questionable turbo life, FICM issues that make starting an iffy proposition and can take out expensive injectors and HPFP issues that can come from nowhere...
If you have one of these fine examples of Ford engineering, you are kinda stuck with it...so bite the bullet and 'try" to mitigate the potential problem areas...but if you do not have one...why set yourself up for gut wrenching anxieties about when the next disaster may happen...BTDT too...
Regards
