klr650goldwing's avatar
May 09, 2019
Ford Diesel trucks
We are in the market for a Ford Super Duty F350. And, I'm afraid the V10 gasser is going to retire. I have really enjoyed our current truck, but we just bought a GD Solitude which weighs 2500 lbs. more than our Cruiser did. We are looking for a used truck and my question is if there are any years of diesel Fords that I ought to avoid?
  • RoyF wrote:
    My 2008 F350 has the 6.0 diesel, and I have put about 15,000 miles per year on it, and most of that while towing.
    May want to recheck that. If you actually have a 2008, it does not have a 6.0 PSD under the hood.
  • ppine's avatar
    ppine
    Explorer III
    The 6.0 engines can be greatly improved and made much stronger for about $3,500 by a good mechanic.
    Everyone likes the new trucks but they are complicated and plenty of sensors.
    One option is to buy an older truck like a 7.3 and put some money in it. Still much cheaper than a 2012 or newer truck and less complicated.
  • Go with any year 2012 or newer. 2011 was the first year of the 6.7 diesel. Very good engine but I never wanted to buy anything of first year production.
  • "are any years of diesel Fords that I ought to avoid?"
    HAAAAA, that's a loaded question.
  • I’d confine my search to 2015 and newer Ford Diesels.
    And, I admit I’m biased as hell on this, but I’d try to find an F450. Ignore the 14k gvwr, as it is capped at that level to keep it a class 3 truck. They weigh more than an F350 because they have heavier axles, bigger brakes, and 19.5” tires. They also have a much tighter turning radius than the F350. They are more capable than the ratings may lead you to believe.
    I’ve had two, a 2010, and a 2016.
  • I don't have actual numbers on the 6.0, but my guess is that only a small percentage of them had the major problems. My 2008 F350 has the 6.0 diesel, and I have put about 15,000 miles per year on it, and most of that while towing.
    (Thanks seminole30 and shum02: I have the 6.4L, not the 6.0)
  • The ones with the 6.0L engine have a bad reputation and the 6.4L isn't a gold plated either but not as bad. But some folks claim they work just fine. The 7.3L engines have a great rep but are getting quite old and can be hard to find.
    But the newest 6.7L has been mostly trouble free, so anything later than 2011.5 should be good.
