lumpy790
Mar 15, 2014Explorer
Ford Dually pressure check?
Ford in their infinite wisdom puts the valves facing the inside of the dually wheels so ..... how do you check the rear tire pressure? I have chrome wheel emulators making the holes in the wheels slightly smaller. I bought a angled top and bottom air gauge but still can not get to the valve
I put on extensions that when 1st installed worked perfect but after the 1st tire rotation have been chasing intermittent air leaks & flat tires. Temp seems to change the stem adjustment.
I am getting 6 new tires next week and thinking about dumping the extensions if I can find a way to check the pressures.
Has anyone ever seen something that will eliminate the two rear tires and replace with 1 wide tire? Like tractor trailers are now doing?
