ACZL's avatar
ACZL
Ford dually rear center cap removal
Took our new steed to tire gurus to have them check things out as to why we had a slow leak in RR outside tire. Purchasing dealer is 1/2 hr away, tire gurus--several minutes. The center cap posed one heck of a problem for them as they couldn't get it off---but did eventually but in process scratched up the rim near the cut out/slots you are supposed to use to pry it off. Not sure what they did use, but know that tool kit in truck from Ford didn't have anything that would work. So my question is, what tool will work best?
The leak BTW was a very badly corroded TPMS. Was built in Oct '17, went to MA originally, then here in NY. Had 300 mile on it.
  • stickdog wrote:
    A couple things: first there is a known problem with the TPMS on the 2017 Ford DRW's with corrosion. There is a thread on a ford fourm about it. I had one go bad on my 2017 replaced with a non TPMS as they were back ordered. Only reason they were back ordered was they can't keep them in stock.
    Second I couldn't get my rear hubcap even tried the ratchet straps wound up ordering hubcap removal tool still had to remove the rubber mallet head but it works.
    Thanks for the replies again folks!!
    Ironically, the tire shop did have the same tool and just couldn't get enough leverage between the cap and rim to pry the cap off. Almost like it was "super glued" on.
    Also, thanks for the heads up on the bad batch of sensors. Will advise tire shop so they can look into getting me replacements---unless Ford is replacing them free of charge.
  • I use a brake adjusting tool wrapped with electrical tape to keep from scratching the wheel.
  • A couple things: first there is a known problem with the TPMS on the 2017 Ford DRW's with corrosion. There is a thread on a ford fourm about it. I had one go bad on my 2017 replaced with a non TPMS as they were back ordered. Only reason they were back ordered was they can't keep them in stock.
  • Ratchet straps will work. Corrosion on the valve stems with 17 and up Ford duallies is a problem. I have had 4 replaced and another is starting to leak again.
  • Can't remember which truck site I saw it on but a ratchet strap with small hooks is about the best solution I've seen. hook on each side around a 2x4 across the tire.
  • In jack kit for my F350 dually, the lug wrench has a hook opposite the socket fits the center cap slot. I use it to pull the cap.
  • AZCL, if the center caps remove like my Ram dually, you mentioned a slot. Ours also has a slot between the wheel and cap, with the slot being on the cap. Under our passenger seat is the tool kit and jack for changing a tire. There is a straight steel square bar that is about a foot long with a hook on one, just an "L" bent to a 90 degree angle. You really can't grab the square bar , or I can't, to pull the cap off because more often than not it just jumps out of the slot or if it pulls the cap off, you can easily end up on your butt. What I have been doing is putting a vise grip on the outer end of the bar and hit the vise grips with a dead blow hammer. Has been working every time since I started to do it that way. My vocabulary has sure been better!
  • I’m sure there’s some special removal tool, but I keep a Wonder Bar in my truck just for removing the center cap on the rear wheels. Use the hooked end in the slots and it pops right off. Wrap some tape around it to prevent scratches.
  • Sounds like it was driven in a lot of winter salt, and not washed off.
