Buck50HD
Apr 16, 2014Explorer
Mike Up wrote:Buck50HD wrote:
Mike, your math is correct but you missed something. There is an 11% reduction in HP/wt of the base vehicle but it will be used for towing.
If you consider my GCW was 15,500 with the F150HD, my heavier 6.2 will push that to 16650. Given those totals, here are some comparisons of the eco, 5.0 and 6.2 super duty.
365HP eco -> 385HP F250 = 1.8% lower HP/wt
360HP 5.0 -> 385HP F250 = 0.4% lower HP/wt
420TQ eco -> 405TQ F250 = 10.2% lower TQ/wt
380TQ 5.0 -> 405TQ F250 = 0.8% lower TQ/wt
So, you can see that even towing, there is a noticeable difference between the eco and 6.2 (particularly TQ) but I've basically stepped back to the equivalent of a 5.0. If you consider the torque curve of the 6.2, it's going to feel better than a 5.0 pulling the same weight.
Now I'll know what your setup feels like compared to an eco:)
Not sure how you figured out your numbers because none make sense to me.
BUT as I stated, the "TORQUE" to weight issue is the one I was looking at, not HP.
The dealer loaded XLT F250 6.2L Screw had the 3.73 open differential, chrome package and everything my loaded XLT has. The F250 added telescoping mirrors and tailgate step.
The F250's GVWR is 10,000 lbs, and it's Yellow Tread Act Tire Loading sticker stated the payload was 2833 lbs. So to get the real weight of the actual truck, subtract that 2833 lbs payload from it's 10,000 lbs GVWR. You then have a truck that weighs 7,167 lbs.
My truck in the signature weighs 5768 lbs. My GVWR is 7350 lbs and my Yellow Tread Act Tire Loading sticker states my payload is 1582 lbs. So 7350 lbs - 1582 lbs is 5768 lbs
So the F250 is 7,167 lbs and my F150 is 5768 lbs.
Now the Torque for the F250 is 405 lbs at 4500 rpms. Using 7167 lbs / 405 ft lbs = 17.696
Now that we have the torque to weight factor, we can use that against my truck by taking it's weight of 5768 lbs and dividing by the same factor. 5768/17.696 = 326 ft lbs.
So with the same torque to weight factor as the F250 6.2L, my truck would only have 326 ft lbs at a more lofty 4500 lbs. My 5.0L offers 380 ft lbs at 4250 rpms.
So you can see that the F250 has significantly less torque than my truck, to pull a heavy trailer. And on top of that, that torque peak is at an even higher rpm.
In fact the torque factor of 17.696 is even lower than what my Sport Trac V8 had. It's 4.6L offered 300 ft lbs at 4000 rpms. Without it's factory hard tonneau cover, it weighed 4,992 lbs. 4,992 lbs/ 17.696 would be only 282 ft lbs at a much loftier 4500 rpms.
As you can see, even my Sport Trac had more torque at 500 rpms lower than the F250.
Now, I'm not saying that the motor is bad because I like it. I'm just saying that I wouldn't want to pull more than 9000 lbs with it.
I've towed a 5000 lbs loaded Jayco Jay Flight 19BH with the Sport Trac and it towed it extremely easy. The F150 tows the 6500 lbs loaded Jayco Jay Flight 26BH even easier. So both trucks have a lot of reserve power that's not used.
I feel the F250 6.2L could pull a 9,000 lbs Loaded Jayco Jay Flight trailer, but it would be right at it's limits of offering a stress free tow.
I see your 5th wheel is right about 9000 lbs so it's obviously working out for you, no big deal. I'm just saying I wouldn't want to tow a heavier trailer without upgrading to more power, that being the 6.7L Diesel.
I loved the F250's stability and ride quality, and especially it's very high 2833 lbs payload for such a loaded truck.
I would buy it without reservation to tow if I need the extra capabilities of the Super Duty chassis.
For pulling a camper that's 9000 lbs and the need for high payload, I'd order a 5.0L Screw 4WD Heavy Duty Payload option truck. I looked and none were available so I'd have to order. I don't have the luxury of ordering and waiting around. I actually didn't need the extra payload as it turns out and don't plan on ever getting a bigger or heavier trailer. If anything, a smaller one. ;) So I lucked out in my truck working out good for me.
I'd still like a F250, but for $10,000 dollars more including my X-plan and rebates, it just wasn't worth it for 'me'.
I'm glad you like your truck and it's working out good for you.
I think we agree. My point was to calculate HP and TQ to weight ratios using a gross combined weight while pulling a 9k trailer. I know it's slower with the bare truck but when you hook up 9k, the 1150lb heavier truck is a very small % of the total.
BTW, I took it for a spin for the first time last night and wouldn't hesitate pulling 12k with the way it handles 9.
44,066 PostsLatest Activity: Jul 25, 2018
