I'll find his email and phone # and post it. He seemed very reasonable compared to getting another used seat in good condition which were $700 and up. On another board someone posted swapping modules from passenger side which I will check into. Sorry to read about your trans issues hope you get it back up and operating (in reverse), in the meanwhile you can just use pull thru sites lol!
BurbMan wrote:
Unlikely it's the motors...any way to test one by applying 12v directly to the motor using a jumper? If one motor was good then I would assume they are all good and start with the module. Try Googling around, I found a place in Idaho called Module Masters when I needed the ABS unit for the Suburban, I got a rebuilt one for $250 instead of the $1200 the dealer wanted for a new one.
You might also see what other models this module was used on and see if you get one from a salvage yard.
I would be interested in the name of the company you found for the seat...I have a few rips on the drivers seat bottom and if I can get just that cushion recovered to match the OEM leather then I wont have to go to seat covers.
