goducks10
Apr 29, 2018Explorer
From the PickupTrucks.com article.
How It Tows
Where the 3.0-liter Power Stroke engine works less well is — surprisingly — towing. I sampled two different setups: An F-150 with a 3.31:1 axle gears (which is what you get when you specify the FX4 Off-Road Package) that towed a 6,240-pound box trailer and a second half ton with an optional 3.55:1 axle ratio hauling a 5,500-pound horse trailer. Off the line, the new Power Stroke exhibits excellent initial low-end grunt and has absolutely no problem moving these loads up hills at speeds below 40 mph. But once the speed and rpm begin to climb, the transmission starts to behave in a way that keeps this engine from shining like it should.
Towing up a hill with a 3 to 4 percent grade at 55-60 mph, I routinely slowly lost speed despite having my foot to the floor. Even with Tow/Haul mode selected, the transmission refused to kick down from 6th gear, despite having another 1,000 rpm before redlining. The struggle was most noticeable in the 3.31-equipped truck, with the 3.55-equipped truck only slightly less out of breath, but until I slipped the transmission selector into manual and dropped a gear myself, no more oomph was to be found. Once I took over shifting duties, performance felt a little better.
How It Tows
