Area13
Jul 06, 2014Explorer
phurley wrote:
I have a Ford F250 that is paid off and would like to use with a truck camper. I have been using it with a TT.
It's specifications are 4x2 Crew Cab Wheelbase 156.2" GVWR 8,800 Maximum Cargo 2,080
I am looking for something that has a slide. Is that possible with my maximum cargo at 2,080?
With that years Super Duty, 250 and 350 are basically the same except for 2" and 4"blocks in the rear, it's a good platform. Mines an 02 4X4 burt similar. You have to spend some money to beef it, i'm in the process. You won't find hardly anything, especially with a slide to stay within those numbers, so if you're not comfortable with that, forget it, IMO.
I have added aftermarket wheels and tires that are rated for well over 7k per axle (VERY IMPORTANT), along with airbags, upper bump stops to engage the overloads sooner,Huge rear sway bar, tuner with tow and decel tunes.
You have to be careful choosing a camper if you go this route, numbers on the campe sticker lie and you will never know the true weight until you load it up and hit the scales. The camper I chose has a slide and is 9'6" and not very light, but less than some like Arctic Foxes. Mine also has a COG very far forward to put some weight up front. When I bought mine and hit the scale loaded up it was 6220 rear axle weight, not terrible for a slide, I have some tongue weight and grocery space left, just no dry camping (tanks empty) while transporting my boat.
44,060 PostsLatest Activity: Mar 26, 2026
