jlsdcen2's avatar
jlsdcen2
Ford F250 6.2 Liter gas any good?
I am looking into purchasing a new Ford F250 with the 6.2 liter gas engine and 373 gears. Does anyone have any experience with this motor? It has only been around 4 years. I currently tow a 6000 lbs TT with a 2006 F150 5.4 liter, does the job on level roads but struggles against the wind or up hills.
  • Slownsy wrote:
    Toving FW 10000 lb 10 mg no proplem and I used to have a 7.3 disel.
    Frank
    How about empty @ 75 mph?
  • Toving FW 10000 lb 10 mg no proplem and I used to have a 7.3 disel.
    Frank
  • My buddy just did it. Night and day between the 6.2 and 5.4. You will love it.
  • Jack_Diane_Freedom wrote:
    I have had a 2011 F250 with 3:73 and 6.2 and current 2014 with the same towing 8000lb TT and handles the trailer effortlessly. Would recommend without hesitation.
    What kind of mpgs have you experienced?
  • I have a 34 foot gooseneck horse trailer with living quarters that weighs 14,000 lbs that I pull with a 2013 F350 Dually CC with 6.2 engine and 4.30 rear end. Truck pulls this trailer with no problems - traded a 2006 6.0PSD F250 for the 6.2 gas engine with no regrets - I pulled the above trailer with both trucks and both pulled it equally well- you just have to learn to keep the gas engine in the higher rpm ranges. I had to order my F350 DRW as I wanted a 2wd with 4.30 gears with a gas engine - odds of finding that combination on a dealer lot is slim to none. If you're not ever going to tow a heavier trailer than what you have now, the 3.73 gears should be fine. The 4.30 gears are awesome and only hurt the mpg about 1 mpg. I believe you will be very impressed with the 6.2 engine, especially over the 5.4 - I won't be surprised if the mpg is higher with the 6.2 over the 5.4. Good luck.
  • After towing with the 5.4, you would be in for a real treat, towing with the 6.2, with 6-speed. Both the engine, and transmission, will be a huge upgrade! I made the same change myself.
    Good luck,
    Jerry
  • See if you can find one with the 4.30's, it will make towing easier.
  • I have had a 2011 F250 with 3:73 and 6.2 and current 2014 with the same towing 8000lb TT and handles the trailer effortlessly. Would recommend without hesitation.
