Just for the record, many Ford pick up truck frames have a moon shaped cut out in the lower flange to provide clearance for the shock absorber.
Frame cracks on Fords equipped with air bags typically initiate from this lower flange cut out area, which is very near where the air bag mounting apparatus is bolted. The crack propagates upward, until arrested by an existing hole in the web of the frame. Very common.
The most important two parts of a C channel truck frame are the upper and lower horizontally oriented flanges. The vertical web of the frame's main purpose is to keep these two highly loaded flanges at a prescribed distance from each other. Ford permits drilling into the vertical web, but forbids drilling or modifying the all important horizontal flanges. The upper and lower flanges are subjected to the greatest proportions of compression and tension.
So it is not surprising that an already scalloped lower flange cracked when subjected to a concentrated load placement (from the aftermarket airbag) in an area of the frame that was not designed to bear that load. The frame is designed to take the load at the spring hangars, not at a mid point between the spring hangars.
All the air suspensions on big semi trucks and trailers are completely irrelevant to this discussion. The issue isn't air or bags. The issue is placement of stress on a specific area of the frame that was not only not engineered for it, but is in fact actually weaker in that specific area due to the half moon shape scallop out of the lower flange for the shock clearance.
For this reason, if more rear spring capacity is needed, then a heavier overload spring might be a better way to go on certain Ford pick up frames.
