Big Toe, that is exactly where mine cracked. It ran for 9 years before it did.
By adding the Stableloads, more of the load is transferred to the overload springs much earlier than previous.
Tici2,
The procedure is a little too long to detail here, but basically you turn off the fridge, unplug everything and remove the board cover. All will be unplugged except the big multi wire plug, then plug the 12v hot and ground back in, turn the fridge back on and ground pin #15 in the large plug with a jumper wire. Pin 15 is the 2nd from the left on the top row. There is no wire in this pin hole. Ground for about 5 seconds. Then plug it all back in and turn the fridge on.
I am pretty sure there is a thread already on this site, I will try to find it and post a link.
EDIT:
check this link
http://www.ehow.com/how_7679848_reset-norcold-control-board.htmlDale
