Chrisatthebeach
May 19, 2014Explorer
HPOP seal, oil filter loose or has failed, also the copper o-ring on the drain plug can fail, mine developed a pretty good leak, not as fast as yours but a pretty good spot on the garage floor. I checked the drain plug and it was tight, went to change the oil and the copper 0-ring was still there but would not seal, changed it and all good.
44,057 PostsLatest Activity: Mar 12, 2026
