ACZL
Jan 31, 2016Explorer
Well I used the sled trailer again this w/e and same thing happened. So I took it to our RV dealer and they discovered that 3 of 4 brakes were seized up. WTH? They are Dexter Never adjust brakes and have had this trailer for less than 2 years (brand new)! They had 4 manual adj brakes on hand, but I told them to button it up and I will call the trailer mfr to explain to them what was found and see if either they or Dexter can help. Dexter's web site says they have 2 yr warranty and RV dealer says it's a 1 yr warranty on whole assembly they's put on.
As for the connect/disconnect, this what's happening and it makes sense now. The truck sends a "signal" to any trailer being towed. As long as the "signal" comes back to the truck, nothing happens. If the "signal" doesn't come back to truck, it says "trailer disconnect". If while in the "disconnect" mode and another signal comes back, now display says "trailer connected". They believe the cause of this is due to the 3 brakes being bad and thus shorting out someplace and likewise brakes not working. When I asked how the brakes got this way (cause), I was asked where I parked it for the summer (on grass w/ possible weeds) and their reply was moisture from grass/weeds. It was suggested to either park on gravel, concrete, blacktop or at the very least--put plywood down under each side. If not, take trailer out once a month, hit brakes several times to "free" things up. Can take wheels off and lube things up w/ never seize if I want to as well instead of taking it out. No cost to park it where I do for the summer, but there is a storage place 1 miles away that has the stone/gravel lot.
What would you all recommend?
BTW---No problem w/ truck was told.
44,055 PostsLatest Activity: Dec 23, 2025
