mfoster711's avatar
mfoster711
Explorer II
Aug 16, 2015
Ford Tow Haul Mode - Do you use it?
I previously had a 2007 F250 Diesel. It had a tow haul mode for the transmission but I only used it once because it did not seem to make much difference and caused my gas mileage to stink. I might be wrong, but I think the tow haul mode would disable overdrive which is probably why my gas mileage stunk.
I now have a 2015 F150 and did some towing today with and without the tow haul mode on. In my F150 it seems to make a bigger difference. When tow haul mode was off I felt like the transmission was shifting way too often. With tow haul mode turned on the transmission shifted less often and seemed to drive better.
I guess I will just drive with the tow haul mode turned on but I was wondering what others do? Do you use it on your F150? Does it make the gas mileage a lot worse?
