Kalabin wrote:
colliehauler wrote:
So far I've replaced the clutch assembly, plugs and coils, tps, heater core, windshield, and had the seat repaired. Still need to fix dash lights and put on a set of tires.
How do you tell what ratio gears in differential?
When you open the drivers door there should be a sticker that says "Axle Code", I believe for my Excursion it's C1 = 3.73, C2 = 4.10 and C3 = 4.30.
Yep! Unless someone like me changed out the gears. Which I have a notation in the glove box, and on a tag on the diffs.
