- Cummins12V98Explorer III
larry barnhart wrote:
My thinking has always been this. It is your money. buy what you like and no need to run down what others buy because it doesn't help anyone. If your purchase doesn't turn out to be a good thing buy another brand. It is still your money.
chevman
EXACTLY!!! - the1admanExplorer
Cummins12V98 wrote:
the1adman wrote:
I am a hardcore Cummins fan, owned several of every generation since 1993-first gen. I have a 2021 3500 HO Aisin, there is plenty of room for improvement. The Cummins and the exhaust brake are flawless, the transmission not so much.
The Aisin isn't terrible, just not the ultimate transmission so many make it out to be. My 2017 with the 68 RFE wasn't really much worse when towing 15K plus. I don't know if that's saying a lot about the 68 RFE or little about the Aisin.
I am the odd minority that wants a manual transmission, I never had a complaint about any of the manual trucks I owned. I would jump all over a quality manual transmission option, I know those days are past and probably never see that option again in a new diesel pickup.
Guess you should sell the POS you just bought and look for a 13 and older 6 speed stick.
Never said it was a POS or that I wanted to sell it. I ran nothing but Dodge Cummins for my business. I have had multiple trucks of every generation over a 30 year period. I work hard for my money and want to purchase what I feel is best for me and my money.
I stated my opinion of the Aisin and never mentioned you, your truck or your repaired Aisin and yes I followed that saga on another forum. Even if you have stock in Aisin, I can't believe how personal you take someone giving praise to anything other than what you own. Cummins12V98 wrote:
"His Asin has been on the shop floor " You know the story and it had NOTHING to do with the AISIN.
This is what people do they say partial truths to make people believe the story is one way but in fact it's another.
NEVER an issue with my 68ref towing 29k combined for 65k. Only issue was taking off on grade with 3.42's. So if it was so bad I should have had an issue. Trans was near spotless when I removed the MagHyteck before trading on current 15 and upgrading to current 24k DRV. I ran the hell out of mine during the leaning process and it always had solid shifts, no flailing etc.
You guys bitching about the AISIN and 68rfe sell the POS you have and buy a GM or Ford for god's same!!!
I think it had everything to do with the Aisin. It was the Aisin that was removed to be worked on. Maybe the tech working on it made a bad situation worse.
Bottom Line: Medium duty doesn't mean a thing when it was your Aisin transmission on the shop floor and your truck out of service!- MFLNomad IIThat is good thinking Larry! I've purchased many types of vehicles over the years. If I had an issue with a car, truck, motorcycle, snowmobile, or trailer, that made it not enjoyable, to use/drive, I just traded for a new one. Now if you want to talk about expensive trades, try trading spouses!
Jerry Bionic Man wrote:
FishOnOne wrote:
Bionic Man wrote:
FishOnOne wrote:
Bionic Man wrote:
More gears isn’t all about getting to the top of a hill (that most people will never traverse anyway) faster. It’s the driving experience. I really don’t understand why that is hard for some people to acknowledge.
In addition, aside from the marketing aspect, moving to a better transmission with more gears would allow RAM to run one tranny instead of two, and one engine output level, and be competitive power wise in the 2500 again. Pretty silly for them to hold onto the current strategy.
The problem is I don't think Stelantis has transmission engineers so that means Ram will again have to outsource the transmission and if that transmission is only used in Ram HD trucks it will be extremely expensive.
A version of the Z 8HP works in the Demon. I’m sure with adjustments it could work in the Cummins. Or, heaven forbid, go the route that GM did with the current “Allison”.
And how much inefficiency do they have with two output engines and two separate transmissions for the same truck?
I don't believe that transmission is designed for a PTO provision.
Good point. How would an outsourced transmission be more cost prohibitive than a outsourced engine? Or the current Aisin for that matter?
RAM has no choice but to outsource the diesel engine. Remember Daimler threatening to install a Mecedes diesel under the hood of the Dodge trucks. It would have been a lot cheaper for them to do that.
As for Aisin transmissions... Again, there's a reason that the majority of RAM trucks both 2500 and 3500 have the 68 transmissions in them. Cost!- larry_barnhartExplorerMy thinking has always been this. It is your money. buy what you like and no need to run down what others buy because it doesn't help anyone. If your purchase doesn't turn out to be a good thing buy another brand. It is still your money.
chevman - MFLNomad II^Musta stayed up late/out too late, just seem a bit grumpy for Sunday morning? :)
It's okay though, happens to all of us on occasion!
Jerry - Cummins12V98Explorer IIII love my True Medium Duty "outsourced" AISIN/CUMMINS combo. My shifts are solid, no dead pedal and my engine has performed GREAT towing MUCH more weight than any of you are. That's WestCoast towing not flatlander like many do.
Don't like what RAM has to offer go to GM and Ford. BUT there is a reason most RV haulers and HotShotters that OWN their trucks are driving RAM. - Cummins12V98Explorer III
Guess you should sell the POS you just bought and look for a 13 and older 6 speed stick. - Cummins12V98Explorer III"His Asin has been on the shop floor " You know the story and it had NOTHING to do with the AISIN.
44,056 PostsLatest Activity: Dec 27, 2025
