Considering its roots, I would expect it to be trouble free.
The V8 shares design similarities with the Modular engine family such as a deep-skirt block with cross-bolted main caps, crankshaft driven gerotor oil pump, overhead camshaft valve train arrangement, and bellhousing bolt pattern. In particular, the 6.2 L V8 features a 2-valve per cylinder SOHC valve train with roller-rocker shafts and two spark plugs per cylinder as well as dual-equal variable cam timing. The single most significant departure that the Boss engines make from earlier Modular engines is that they have much wider 4.53 in (115 mm) bore spacing (compared to the Modular's 3.937 in (100.0 mm)), allowing for the use of larger bore diameters and valves.
