whizbang
Jul 03, 2016Explorer II
Glueing won't do. You need a solid connection to the gray tank, and probably a flexible connection to the drain line.
I would recommend removing the gray tank and replacing/reinstalling a new flange and elbow.
After you reinstall the tank, replace a couple feet of the black ABS pipe with flexible rubber hose so it won't vibrate apart again.
You have a great camper, but there is no easy fix. Do it right and solve the problem properly. Good luck.
44,056 PostsLatest Activity: Nov 19, 2013
