RickW
Jul 17, 2016Explorer III
just a $0.02 thought,
In the second photo, the pipe is rigidly fastened with pipe strap to the top block. If the tank top moves (thermal, road vibration, etc) the tank joint may pull apart again. The original flex joint might have been designed to be back at the hose coupling.
If you believe the tank top can move, consider loosening that pipe strap and line with soft pipe insulation.
44,056 PostsLatest Activity: Nov 19, 2013
