BurbMan
Mar 18, 2019Explorer II
Free Camper Adventure: Moved Successfully!
Finally had a nice day here yesterday so I got over to the storage yard where the camper is. Reinstalled the LF jack, tightened the bracket bolts, and checked the rears too. Since no battery onboard or electric, I used the hand crank to verify that all the jacks worked. I just went up a little, just enough to take the weight off of that corner to where I could slide around the boards underneath.
Now for the problem area in the RF...the 1x2 on the front frame was still solid, so I was able to thru-bolt the jack bracket to it. Since that corner bottom is separated, I used a ratchet strap to keep the jack from leaning out with weight on it. I was able to jack the camper the same 1/4" as I did in the other 3 corners and didn't hear any crunching, creaking or otherwise bad noises.
From what I can tell, the jack is carrying the weight from above, meaning that little 1x2 is in compression, and it should carry the weight as long as it stays straight.
All I need to do is keep it on the jacks long enough to get the blocks out from underneath and back a trailer under it. What do you think? Doable? What are my other options for lifting this corner aside from a crane with a sling?
