Old-Biscuit
Jul 26, 2017Explorer III
Depends.......
DO you have a water panel with valve/switch tht goes from 'city water' to 'fill' ??
Or a 'gravity fill port''where you have to put hose in to fill fresh water tank
'Fill' then it could be the Anderson Valve
Gravity Fill......
Then it is the water pump internal check valve not sealing.
Turn off city water....use pump and flow thru pump from tank MAY clear debris/mineral scale from check valve
Gravity Fill......
