Graycat
Jul 27, 2017Explorer
rv2go wrote:
Sounds like the check valve in the water pump is leaking. Take the pump apart and clean the valve. Or, you can install a check valve at the pump. Just make sure it's on the correct side.
Ours did that, and this was exactly what it was. By the time we found it, the pump was toast. See if there is water puddling around the pump anywhere. Once Hubby replaced the pump, all was good.
