ksg5000 wrote:
Miss Sunshine wrote:
Smells both hot and cold.
I always sanitize the HWH.
It’s an Atwood. So no anode. Oh, isn’t the lining aluminum? Is it reacting with the softened water?
Tank is glass lined so I doubt that's an issue. If it were me I would try filling the tank from another water source just to rule out your current water source as the problem. Your house may have water softener but it may bypass the outlet your filling the RV from. Also - if you have a built in water filter that maybe the problem.
NO ...Atwood WH Tanks are NOT glass-lined
That would be the Suburban which uses a STEEL tank and glass0-lining to protect steel tank plus anode rod
Atwood uses an ALUMINUM tank that has a zinc cladding so no anode rod is used.
Softener is not your issue
Both cold and hot smell........that is source water supply
How old is your Hose?
Did you sanitize it?
