Bobbo wrote:
StirCrazy wrote:
how are you sanatizing,just putting it the city water conection or putting it in the tank fill? Are you runing off your fresh water tank or are you hooking up to city water when it smells?
I had it when I was hooked up to city water it would taste/smell funny but when I used the onboard tank it would be fine. my sanatize process was using the fresh water tank as the source so it never got that bit bettween the city atachment and the water pump , so now I sanatize both ways.
Steve
After filling all of the lines with the bleach solution, open a faucet to relieve all of the pressure. Then, and only then, go around and push on the button in the middle of the shore water inlet and bleach water will backflow out of it so it gets sanitized too. BE SURE THE PRESSURE IS RELIEVED FIRST OR YOU WILL DAMAGE THE BACKFLOW PREVENTER!
what button are you talking about? I am not sure even if i have this button how it would back flow up hill.
Steve
