oldokie
Aug 14, 2015Explorer
Fresh Water Tank Drain
The drain fitting location on my fresh water tank is in the end of the tank about 3/4 to 1 inch up from the bottom. The pump pickup fitting is also located in the same way. This is a 60 gal. tank that measurers 7 by 34 by 64. I cannot drain or pump the last 1 inch of water in the bottom of the tank. I think this amounts to about 7 gals. Have you ever put a low point drain in the bottom of a polypropylene tank in order to drain all the water out? It seems that this may be difficult to do.
