SpeakEasy's avatar
SpeakEasy
Fresh Water Tank Fill Method
My Forest River Micro Lite 23LB has an external port for winterizing (adding anti-freeze) which uses the onboard water pump. There is a valve setting on the water pump that lets me switch from "normal" operation to "winterizing" operation. (Normal draws water from the tank; winterizing draws anti-freeze through that external port.)
There is nothing in any of my manuals about this.
Can I use this winterizing setting to use the pump to fill my water tank if I attach a full 5-gallon aqua-tainer, or some such thing, to the anti-freeze port?
It seems that I should be able to do this.
-Speak
