Camper_Jeff___K
May 15, 2021Navigator
Trying different method of fresh water tank sanitization
Completion Video Thread:
Today, I'm going to try the hot white vinegar solution method for cleaning the water system. I usually do 1/4 cup bleach in 35 gallons and leave it sit a couple hours, then flush it out.
The vinegar method requires a couple gallons white vinegar to 35 gallons water. You then turn on your water heater and with a hose adapter if necessary, connect a hose from your kitchen sink fawcet out the door and into your water tank fill. You then turn on your hot and cold water and keep recirculating the water until the water temperature is 130 degrees F. This method is considered safe and effective. It is also supposed to help clean calcifications in the system. Not a big deal in the PNW but in other parts of the country. It's also recommended to swap out your water heater anode afterward. I will let y'all know how things work after I finish.
J&K
J&K
